Well if the gauge moves the cam sensor is good. Are you sure you got it timed perfect? I don't know too much about the Duramax motor but I know on other engines if they are not in time it will throw a code happened on a 240 I did years ago and the Ol lady's stratus when I changed the timing belt.
Sent from my C811 4G using Tapatalk
What's the code again? do you have the full description? You said you deleted the fprv right? And when you unplug the fpr harness it runs? Maybe it won't run with it deleted. Is there any tuning the goes into getting rid of the valve to bypass the code? Sorry for all the questions.
