New mods for this year drag racing?
emiller3
He's Back
Feb 21, 2009
3,586
42
lake charles,LA.
Wastegate for little charger,60 over nozzles, s480 to hang on side of the danville ,airdog ,new pitman and idler arms ,and a modded intake bridge.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
new driveshafts and tcase,trans,motor, cage ,rad, fuel cooler, crossmemebers
and a blockerplate all so i can go slower than last year:thumb:
DMAXchris
It’s only temporary!
Apr 28, 2009
2,273
Natrona Heights PA
Turbo, nozzles, up pipes, EGR delete, downpipe, boost tube, left manifold, A set of Toyo Proxes St1s on PYOs, Rancho 9000xl's
I think that's it.....:D
VeeAte
going for 10s
Dec 7, 2010
177
ocean springs, ms
Garrett 4094vvt, full egr delete, wicked stage3 cp3,60% lbz injectors, suncoast gmax6 w/ precision ml, rdl manifolds/up pipes and finally a set of gauges :D got the turbo on now, the rest will be done by Diesel Addiction in june :thumb:
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
Got new NV serires gauges installed tonight along with the transfer case. Got the saftey loops put around the traction bars. Now I just need to install a drive shaft loop, Fittings on the tranny cooler, shave some weight Gears and im good
BUST'EM 504
1,047
lowered for better angles, pyos with general grabbers, up pipes and manifolds, 45 overs,
rancho 9000, and last but not least bed mounted wing to help aerodynamics :rofl:
jakejarrett03
Apr 8, 2011
West Jordan, UT
Well I'm doing Trent's from EPR Triple turbo kit, Stage 2 Trans, Carrillo Rods, LB7 high temp coated pistons, ported heads, up pipes and manifolds. head studs. 20" BMF Wheels with Nitto Trail Grapplers,QA1 Shocks, kryptonite tie rods, Cognitios, 45% Injectors and CP3 regulator. I think that's all for me. :woott:
