LLY: New INJECTOR NOZZLES NOW WONT START
bmos37
Nov 23, 2008
176
Gainesville,FL.
Well i went ahead today & purchased the line that clips to the top of the injectors I tried to purchase it from a couple vendors here but did not get a return call, so went ahead & got it through the local stealership wheat a scam they got on these.192.00 shipped to them. As far as the shims,,,well i bought 2 injectors so far (used) I am looking for a few more just in case they can be cores as i will only be using them for there parts, so if anyone has some around i need them!
bmos37
Nov 23, 2008
176
Gainesville,FL.
OK,
The route i decided to take is, buy 6 more used good injectors & send these in to someone who can properly install the nozzles. I think this would be the fastest way to get the truck up & running. So my question is does anybody have any good LLY injectors that i can purchase,:rofl:borrow, or trade or whatever? If so i would like to get things moving along as this is the only vehicle i have & the moment.
bmos37
Nov 23, 2008
176
Gainesville,FL.
Well she is alive again:D Man what a job this was, Bad enough i have minimal experience but i had to battle the outside elements of heat,rain,more heat..anyways all is well now & if i could get a lead on where to send injectors to get them nozzled up the right way/
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
do you just want the nozzles installed/swapped? Or do you want someone to hone the nozzels out?
If you just need someone to swap nozzles I can help you out with that.
bmos37
Nov 23, 2008
176
Gainesville,FL.
I just need the nozzles put in correctly, The nozzles are already in the injectors as these were the ones that i supposedly lost shims to. On a side note, I am not even sure i did not do them correctly to begin with as when i put them back in i had 2 fuel leaks & 1 injector i dont think i even had sitting all the way down.with all the fuel leaking i did not get a chance to fill the injectors to fire But i am not going to tear it down again unless i know for sure they are built right.
