NEW in 2024
Cumminskilla
Jun 19, 2024
Iowa
I am Landyn Schuldt from Iowa. I own a 2003 Zf6 speed dually 4x4. White with leather interior.
Here for mostly tuning help. recently started a new job where i could be a valuable employee with the knowledge that i can gain from here on tuning.
Currently looking for a hot tune to run on my Zf6 truck and how to build one.
2,231
Welcome
Do some searching and browse the older threads. Lots of good information on tuning in here
Reactions: Bdsankey
Cumminskilla
Jun 19, 2024
Iowa
where would I start? like I stated I'm completely new to this! i don't know the first thing about making a tune, just setting parameters at this point.
2,231
I'd start with studying the history of diesel and it's progression from the first coal powered one all the way to the common rail we have now. That will give you more information on how they work. You can always back that up with more sources of information on theory of operation.
Then when you have a good grasp of the operation of a diesel and understand what the ECM would need to do to run an engine then open up a tune for the first generation LB7 Duramax and look over the tables. If you understand the diesel engine well enough the tables will make sense. Sure, don't expect to be able to understand each and every table. But you can search for the table number in this and other sites and read up on them.
Then when you get a good handle on the LB7, move to the LLY, then LBZ. Move your way up each generation of Duramax and you'll notice the additional tables and changes to the methods of controlling the fuel.
If you just want to tune your LB7 then you can stop at the LB7.
There are a handful of calculators such as the timing calculator, my defuel calculator and a few othere to help out.
Rule of thumb. Take it slow. Only make small changes to a single table at a time and see how it reacts.
There's not going to be anyone here or elsewhere that will hold your hand the whole way through the learning process. But we will be happy to help dig you how of a hole or assist you when you get stuck. But the learning part is all on you. As mentioned above, if you can get your hand on a Starlite book that would speed the process up considerably
darkness
1,329
393
vegas
Go ahead and download efiLive, it’s free and you can peruse the tables (after you upload your tune). As you read and learn, you can reference said tables and follow the rules and limiters. Plus you’ll need it for the Starlite book. The tunes that come on the thumb drive is worth the cost alone.
Lennydmaxguy
Just another diesel tech
Nov 8, 2023
Somewhere, USA :)
I'll add my recommendation for the Starlite tuning guide. Also, if you want tunes to look through, there are a number on this site, and you can also check this link. There are some hot LB7 Tunes in that collection. I DON'T recommend downloading a file and flashing it straight on your truck. Use the modified tunes as a guide to make your own.
