Any idea on price and also what do you need to I stall this
Normal retail pricing is $175, although Ill be running an introductory sale for the first week. I havent set the intro sale pricing yet, but it will obviously be less than $175. :thumb:
Install is very easy, theres only 4 wires to hook up. Power, ground, valet switch signal, and DSP-5 signal.
If you already have an existing "knob" DSP-5 switch, all you have to do is splice the "DSP signal" wire from my digital DSP-5 switch onto the existing wire that is hooked up to your DSP-5 knob switch. Basically just cut your existing switch off and tie the wire into the digital DSP-5 switch.
If you dont already have an existing DSP-5 switch, the digital DSP-5 switch comes with an ~8' long wire with the proper ECM pin already pre-crimped onto the end, so all you have to do is run the single wire through the firewall and insert the pin into the ECM connector.
Ben
