Need suggestions
Idahodmax
Dec 22, 2015
51
Ok, so I finally got efi, 5in check dp back exhaust and egr delete kit.. how ever I don't got alot of free time to do it all at once.. I was thinking of maybe doing dsp5 and ppei efi live one night, 1 to 2 days later getting the exhaust in and on a weekend doing the egr delete.. is there any reason why this wouldn't be a good idea? I get like 2 to 3 hrs of day light a night after work, and I'm not technically inclined enough to trust my self say I can do the dsp5/efi and exhaust in one night
roxyfever
Feb 11, 2016
191
terrell tx
I dont see why not unless your truck has a dpf then you would have to do the exhaust dsp5 and tuning at the same time then egr later
Idahodmax
Dec 22, 2015
51
It does have the dpf, also a edge tuner with juice. I'm not entirely sure if just unplugging the chip under the hood will safice or if there's a way to Uninstall it
clrussell
pro-procrastinator
Sep 23, 2013
5,928
396
How much driving are you going to do between the two days?
I've tuned a couple trucks and they take them home and do the exhaust themselves.. Had one guy drove about 100 miles with no issues. As long as the dpf is clean you'll be fine for a few miles.
Idahodmax
Dec 22, 2015
51
Well I live less than 5 miles from work one way, but I'm sure my dpf is nice and sooted up since I have level 6 unlocked on my edge and if I get on it it will blow a cloud of smoke unfortunately and my regeneration cycle kicked in at least once a week. With my short drive to and from work I generally have to take a trip to the mountains to get it out of regen. I was thinking if I had to take the old ladies acadia, but who really wants to drive the mom mobile around??
13,636
678
Why not do the exhaust first then just load the tune on right quick after? It takes about 10 minutes to do a full flash. You don't have to install the DSP5 switch if you're worried about that part taking too long.
Idahodmax
Dec 22, 2015
51
If I just load the tune after and not have the dsp5 switch installed, what tune will it be set too?? And does it all just work automatically after I install the dsp5 switch?
Oct 16, 2008
948
12
Idaho
It'll be set to whatever your base tune is in the tune file. And yes, if you have a dsp5 tune loaded then install the switch later, the switch will work normally as if you did it all at the same time.
Idahodmax
Dec 22, 2015
51
Ok, so I got the ppei, if I recall:
1: modified stock
2: 30hp
3:60hp
4:100hp
5:150hp
Or something along those lines, so do exhaust flash and it will be set to setting one? Sounds simple enough
clrussell
pro-procrastinator
Sep 23, 2013
5,928
396
I don't mind driving the mom mobile lol.. However no way my ole lady would own an Acadia
custom8726
2,784
Upstate N.Y
1: modified stock
2: 30hp
3:60hp
4:100hp
5:150hp
9 times out of 10 it will default to 5 (all the way up) in my experience if the switch is not in or hooked up wrong.
Dozerboy
4,892
470
TX of course
Ask your tuner which is your base tune. Or install the switch then the next day do your exhaust and tune it after that.
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
Like joshH said. ExhAust then tune immediately. It will default to the150 tune until you install the knob and To answer your next question you; no, you wont hurt anything driving on the 150 tune. Do the egr when ever you want as the tuning shuts it off. But you should still do it asap since the valve tends to be pushed open under full throttle.
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
My tune defaults to stock base tune, my understanding on the EFI forums is most of the tuners do this in case the switch fails.
Idahodmax
Dec 22, 2015
51
I think I can handle that for a day or two, looks like if weather holds out I'll just be doing exhaust..
One other question.. I was looking at my dsp5 switch and wasn't quite understanding how it mounts to the dash, I get you drill a hole, but I'm not sure how you keep it in place other than using the nut and washers that come with it
13,636
678
The setting without the switch depends on how the tune is setup. You would have to ask the folks at PPEI if they have it set up with tune 5 or tune 1 as the base tune. The switch can be setup to work either way. I usually make the lower tune as the base tune so you aren't stuck in kill mode if you have a switch failure, but everyone has their own methods and preferences.
custom8726
2,784
Upstate N.Y
Thats all thats needed to hold it in place.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
It's done because the dsp files only have a few tables to mod. And every limiter/table you don't have access to would reference the base tune. so you'd want your big tune the base tune so you know you will have all the performance limiters max and mins in check. All for performance reasons
