LB7: Need some alignment help?!
JRODS*LB7
Feb 1, 2012
642
SE Massachusetts
what im saying is i had my truck lifted as high as you can possibly get it to go with lifting keys and got all adjustments in no prob! unless his trucks been hit and somethings bent he shouldnt have a prob either ....thats all im trying to say i agree not all trucks are the same but he should have enough adjust ment to get it in spec.
btw you mean camber not caster
JHForman
Oct 7, 2011
82
Southern Indiana
Here's some pictures of the ucas and how screwed up adjusted they are.
Drivers front
Drivers rear
Drivers front(notice how close the arm is to the mount)
Drivers rear
Pass front
Pass rear
Pass front
Pass rear
Frame mounts aren't bent they measure same distance apart. I also believe they are trying to set the truck to factory specs, not cognito specs.
Sledheadxp800r
That was only my tow tune
Dec 13, 2010
1,151
CT
By the looks of those pics I'd say get a guy that knows how to do an alignment on these trucks. You have plenty of adjustment left.
JHForman
Oct 7, 2011
82
Southern Indiana
yes back to big o since the alignment was still under warranty. They chose to void my warranty after this last trip because im not using factory specifications. first thing the tech told me after giving him the cognito specs was "im not going to be able to get it to these specs" my reply was "cognito says it can be done" and his wonderful reply "cognitos not here aligning the f'ing thing now are they". then he went on to bitch about the engineers only giving .1 degree of variation. he said apparenty the egineer has never aligned an f'ing vehicle. needless to say my truck will be going to a different shop next time an alignment is needed.
