Need some advice for new turbo
crazylb7
SPULN IT
Oct 22, 2008
41
turlock, ca
I'm looking to buy a turbo for my 03 lb7. I currently have a stock ihi that is peaking at about 20 psi and I think it's on it's way out. Now my goal is to locally sled pull and race a little bit and I want to stay in the 2.6 class for pulling. Also I'm trying not to spend more then $ 1800! Now I know that's asking for a lot but does anyone have some advice?
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
HTT promax s366 or any other S300 you can find , if you dont have to tow a s466 would be a good choice also but hard to find used .
SmokeShow
6,818
Lawrenceburg, KY
for that money you have to hope to find something used. otherwise, you might consider buying a used stocker to replace your dying one and keep saving until you can afford a new/good aftermarket turbo.
Where you located, out of curiousity?
Good luck.
TrentNell
Jul 7, 2008
7,543
slc tuah
There is a modified s400 64-71-14 for sale. Is that something to consider?
it should keep you in the 2.6 class , never ran one to see if they are laggy ? if you dont tow i would say grab it . if towing duty's are in your future i would stick with a s300 . or ask some one who has ran one , it might not be bad or laggy at all ?
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
39
Locust, NC
Are you refering to the one on DP? The s64sx with install kit for 1800? If so then yes thats a great deal and turbo. If you are still wanting to tow you might consider going to a small exhaust housing like a .90 or a 1.00. I run a similar turbo with a 1.10 housing and it s a little laggy for towing.
z79outlaw
793
37
Salem WI
Seems be be S465 are very afforable, but your going to have to source a pedistal for it. Unfortunately there also seems to be very few budget minded turbo's for the D-max
