Help: Need shop in Boca raton/Miami Florida
610
He is over by Tallahassee.. Frieghtrain and Todd green are in Tampa.
Only connectors I took apart where injectors, two main engine bale and glow plug.
Last time they where disconnected was 20,000miles again when I had the engine apart..
610
Block grounds are good. Including big strap from block to body.:thumb:
Mitch yes. Plus it was acting like an intake was sticking open. Or injector firing way too soon. I haven't changed the tune in some 15,000miles.
ECM works obviously.. I have been told the 3rd and reverse will work with no TCM.. Tonight is first I've heard of that... I have put the truck I'm gear.. Nothing Happened
Not even rpm pull down.
5,911
You have to unplug the connections from the trans at it should default to 3rd
610
Disconnected the TCM truck has 3rd/R
I'd pull front driveshaft and limp the load in 4L but no definite answer to what is making said noise.. I don't want to make things worse..
Especially with thoughts of a broken crank.. But imo and experience it make too much continuous noise just to have a ripped/cracked crank throw
JD from central florida diesel performance is coming down.. To help
5,911
damn adam, not sure what else to have ya check. gotta be something simple....
S Phinney
4,008
Quncy, Fl
Pull the serpentine belt off and see if the balancer moves around. If it does don't drive it unless you want to replace a few more parts. Namely main caps but it could ruin more.
Harbin_22
3,858
Southern Indiana
Pull the glow plugs, unhook injector connectors and see if an injector is hung open maybe? Something to look at for the electric issue, I have replaced a few entire fuss panels under the hood on LMM's. The will have power on both sides of the fuse but none coming out of the panel. Never had one have the no power to dash but had one that wouldn't crank from it.
catman3126
Ehhh?.... You don't say?
Jul 24, 2012
2,636
NE Oregon
Usually a ton of smoke unburnt fuel with a stuck open injector isn't there? when I have seen it anyway.
DixonM
Nov 20, 2014
Florida
How are you making out? This heat down this way is great isn't it.
And if I had a gooseneck I would offer to help you out on dropping off the load.
