Got some bad noises coming out of the DS head area.
And of course I'm loaded..
Any info would be helpful
Thanks
Thanks
Thanks
That's bad I hope it's just a broke push rod or something easy to fix!
Broke and a 1000 miles from home sucks. I own many cheap tools because of it. Hope it's an easy repair.
Valve bridges look ok?
Pull the bridges to inspect them better and pull the glow plugs while they are off and use a rubber tip air nozzle in the glow plug holes to do a makeshift leakdown test for a dropped valve.Yes the appear to be... Both valve move at same timr
Did you pull the oil filler cap and see if it had any blow by? IS it deleted and no smoke from the pipe?
ground or electrical for sure. check all your fuses?
That engine does not sound happy one bit
