LB7: need opinions on what to do....
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
No it wont :D. Too slow
Id do a full set. Little more coin but peace of mind...and faster than an lbz :rofl:
Polaris7x
Dec 25, 2011
406
loves park, ill
until that set gets eaten for lunch on the injector eater motor again then what? do the same thing??? just go for the lbz, then if they go bad you dont have to rip half the motor apart to replace them!!!:thumb:
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
I take it you haven't actually done a set of injectors on an LLY+. I can do a set of LB7's in about 6 hours, and I just got done doing an LLY that took me about 5 hours. Other than pulling the valve covers off, there isn't much less work involved. Factor in that a set of BOSCH LB7 injectors can be had for $1700 VS the $2000 for a set of LLY's or $2400 for LBZ's, and I'll keep my LB7. And like has been stated, you don't hear of that many injector problems on the new BOSCH LB7 injectors, most of what you hear is what people went through before the 09 revision, junk rebuilds that are not BOSCH units, or hear say.
jkholder09
Jan 8, 2012
1,188
Maryland
with the float between positive 6 and 15 I would look at that cylinder and since you are adding fuel. clogged nozzle if you are lucky, bent rod worst case.
you could just pull nozzle and flush out
Kspen90
<<<got turbos?
Jul 14, 2011
1,433
Burleson, Tx
kspent, in all honesty i think you should just dump some coin on "new"bosch exergy injectors and be happy. the prob most of the time is that people buy cheap remans and end up down the same path again with bad injectors.
but then again and lbz will make you happy
The first time I replaced the injectors I knew nothing of the difference in quality in one vs the other. At the time a part was a part to me, and problems have ensued since then.
I'm still running stock turbo and single cp3 so I'm almost ruling bent rod out of the picture. I'm just not seeing it being a worn ball seat either with it adding fuel and having that much fluctuation and every time I start the truck the max level goes to changes.:confused: I think I'm going to rip all 8 out and send them to exergy and have them tested and go from there. At that point I'll only be down another $400 and I'll make a decision from there.
Kspen90
<<<got turbos?
Jul 14, 2011
1,433
Burleson, Tx
Just cross referenced the balance rates and firing order. The one with the bad rate is #3 but #6 is -2 and #1 is -1.6 and if the fuel rate were that much off with that injector I'd expect the other 2 to be pulling back a lot more fuel. Looks like its time to do a compression test and replace the glowplugs while I'm at it. A burnt valve or piston is certainly a possibility I suppose. I have buried a 1600* egt gauge a few times but it was only for short bursts so idk...
Kspen90
<<<got turbos?
Jul 14, 2011
1,433
Burleson, Tx
A thought that crossed my mind last night, could the cup be lifted in cylinder 3 causing that cylinder to lose compression, therefore ramping up the fuel in that cylinder to compensate for lost compression?
5,911
depends, you loosing coolant?
IMHO, throw a good set of injectors in it and keep truckin. throwin a boroscope down the injector holes wouldnt be a bad idea either
Kspen90
<<<got turbos?
Jul 14, 2011
1,433
Burleson, Tx
A little, but I also have a small leak where the coolant pipe meets the oil cooler. I think my next order of business is going to be a compression test and see what that turns up.
