Need new tires
Big Jack
May 8, 2008
13
SW Michigan
I need new tires and am looking at BF Goodrich Long Trail T/A
LT265/75R-16D1 120R. Anybody have any experience with these. I tow a 12000lb 5'er. Are these going to handle the weight. I don't want to go too big because I don't want to hurt the mileage. Any other tire I should look at? I have a 2006 2500 lbz crewcab longbox.
Big Jack
May 8, 2008
13
SW Michigan
I agree, since I posted I have been looking around and I'm thinking of going with Goodyear Silent Armour's. They are E-rated. Anyone have any experience with them?
13,711
772
A 265/75-16 load range D has the same carrying capacity as the 245/75-16 load range E that came stock on the truck. I see no problem with that tire.
TA Dave
Pontiac Racer
Aug 5, 2008
19
S.W. Florida
The 265/70 is shorter than the 265/75, that's all.
It's all about the capacity of air in the tires. The bigger the tire the more weight it can safely support.
Decide on the height of the tire you want, and just order it in an E for the most weight capacity. The E rated tire also has stronger sidewalls that will help eliminate sway.
Noreaster
2,910
42
Cape Cod,MA
8 plies on a D & 10 on a E. Ive had D&E 285s, the Ds squatted alot more than the Es do.
Thats why they used 265s on 3500 srw rather than 245s
13,711
772
At the same pressure? Because I have seen nothing of the sort on my truck. I had 285/70-17 E range Toyos, and I now have 285/70-17 D range Firestones. At the same pressure they look to have about the same amount of bulge to me, but then again, I never actually took a tape measure to either one.
Noreaster
2,910
42
Cape Cod,MA
At 65psi the Es were alittle stiffer, but the real difference comes in the extra air you can run in the Es 80psi instead of 65psi Ds.
13,711
772
I agree completely with the extra air, and I do think the Es rode just a tad bit stiffer than the Ds do. Still, I think a 265 D range would hold up just fine unless you're hauling a ridiculous amount of weight in the truck, but if you had to choose between the two, I would go with an E over a D. The only reason I didn't get Es this time is the tire I'm running didn't offer an E.
motohed
dirty payback
Apr 15, 2008
486
escondido, ca
i have toyo 35x12.5x18 mt's on my truck hauling 1k lbs constant in the bed and with a race tune loaded 90% of the time and have 13K miles on them with 1/8 miles races. will prob get another 3-4K out of them ( only cuz i didn't rotate for a while or could have gotten another 5-7 out oif them)
i love the stiffness of the E rated tire. but next tire i get will have a prorated warrenty on them for sure!!!!! even though is really love my toyo mts and may even get them again:D
