I bought a 2008 dmax back in may. When I bought the truck it ran consistent high 12's low 13's and my EGT'S usually ran around 1400-1450 degrees at WOT on stage 5 dsp. Now it feels sluggish all of a sudden. My injection rates are normal and it runs smooth but I'm now running 14's in the quarter and my EGT'S are running up to 1700 degrees before it goes into reduced power mode (if I don't let off or dial the EFI live back). Air filter is clean and I have already checked for boost leaks. It has done this with several tanks of fuel and also after filter change. What else would cause it to do this out of the blue? It is a mildly built duramax with a compound s475 over stock turbo setup with stock rod, stock injectors, and stock intercooler.
