Where are you located? Maybe we can point you in the direction of a reputable shop to look at it
I certainly wouldn’t trust knock off brands real far anyway.I was talking to someone who had same issues bought nsbu from autozone wouldn’t work then got another from gm and solved problem does it need a gm nsbu?
Hey good thought there. That certainly would be something to check.When the power steering pulley came off, you said it wouldn't shift right after that? I have to assume that the pulley damaged some wiring in the harness from the tcm to the trans and tcase. You said it would drive normal in 4lo? That is still correct?
