I finally was able to stay in it long enough to run through all the gears yesterday ,I am having a problem with rail pressure , its doing the same thing it did my last run @ RMR .I figured it was the FPRV valve at the time , now it is welded shut and there isnt one in the picture . It seemed to be working fine the firsat night i drove it , but wasnt logging and was only in it a few secound each time i went WOT
Things i have checked so far ...................
unplugged both regs 1 at a time and both will max out rail pressure when unplugged .
using EFI I manually commanded 160 mpa and it holds it perfectly at idle but still wont hold it during a WOT run , ( see attached log )
un-hooked my feed line and routed it to a pan and turned on lift pumps , it pumped fuel out faster than then funnel could drain it ,about 1 gallon in 10-15 seconds so it doesnt seem to be a supply problem .
have spent alot of time looking for leaks and cant seem to find any that are visual any way .
still need to do a bottle test
haven't seen it making any oil but don't know if i have driven it enough to see it on the dip stick , i will be changing the oil soon so i will visually inspect it when i do .
Any idea's I am missing ?
