Where can I get a signal that operates between 500 and 1500hz? Is there anything I could tap into on our trucks that's this frequency? Trying to set up my lift pump to run variable speeds
I don't want to worry about losing positive pressure wot.
Yeah I know it doesnt push through at 12psi. But what if you need more fuel?! I was at like 13 idle and sucked down to 7 or more. That was with an old filterless fass. Idk if it was a 95, 100, or 150. I upgraded the lift pump this year, but also plan on lot more power. Trying to avoid any complications that may occur.
as long as you're still holding positive pressure isn't that all that's needed???? regardless of hp output? your cp3 is trying to pull and and as long as your pressure feed is positive isn't that saying your cp3 is well fed? it's only positive because there's a restriction of some type.
Am I off in left field here?
