my twins
b_r_a_d_79
Aug 3, 2013
183
KY
Sounds like some sore of boost leak. Check all intercooler boots and make sure the bridge didn't seperate.
disposablehero
used soldier
Mar 29, 2014
179
I'm hoping the y bridge gasket did pop on me. I got a 5" plug with air chuck I'll have to pressure up the system. I have tuning I have to load too.
disposablehero
used soldier
Mar 29, 2014
179
Stock bridge. A profab Shorty is my next purchase. I didn't strap the bridge. I'm really thinking it might be the bridge.
disposablehero
used soldier
Mar 29, 2014
179
Needing it to mount straight to my delete though. I'd imagine they would match up better than being pieces together from different companies. My egr delete pipe is very nicely done. Not a single complaint. Except I forgot the strap. Lol.
disposablehero
used soldier
Mar 29, 2014
179
Found the leak. Boot on the cold side ic. I'll find something to replace it temporarily till I can source some good ones that can actually hold some boost. Found some sources on here. Just have to measure to make sure I get the right ones.
disposablehero
used soldier
Mar 29, 2014
179
Told a lie it seems. The y bridge was blown out and gaskets stretched too much to get them to reseat. Ordered some silicone o rings. 236. From what I've read those will work I'll try strapping the elbow this time. That was my bad for sure. Spent an hour trying to get the thing in with the old rings but it finally ripped one.
bml2200
256
IL
Sounds dumb, fix the problem.................
disposablehero
used soldier
Mar 29, 2014
179
Yeah. I'm gonna use some jb weld along with the strap to try and hold it in. Not worried about it being pretty way down there. I figure both together might be plenty till I do a 1 piece.
disposablehero
used soldier
Mar 29, 2014
179
Bridge solids great now. Truck runs like a beast. I'm only hitting about 39 psi on the cts. So who knows how accurate that really is. I'm not sure how much fuel Zach put to my big tune and I haven't tested for boost leaks. I'll have to get a gauge and a shut off valve with a little extra hose. I'll do it when I put the hot side boost tube in. Drove for a couple hours testing and looking stuff over for leaks or screw ups. Did a few side by side acceleration tests with a few unsuspecting victims. Pulls so much harder up top. I'm happy with her for sure.
