My small life lesson, having others work on your vehicle
mmasuperman12
Hows Your Dangle?
Feb 9, 2009
77
South Berwick, ME
Search on here how to change to LBZ heads and injectors so you can junk that LB7 crap. A guy on here sells the whole setup, bolt on and it does cost but look at how you get ripped off so bad keeping the old junk. If it's a good truck you want to keep this option is worth the time to look into.
Linky for this? got new LB7 injectors but would like to do this instead:hijacked: over
Maricopaagent
Glamis Anyone?
Oct 10, 2011
257
Arizona
Sorry to hear your pain..
I had the Stealership do injectors under the 200k warranty.. 8k miles later, my coolant was full of fuel! Sooo much for the FREE feeling... :thumb:
BIG PHIL
32 valve
Aug 24, 2011
172
Weatherford Texas
guys... I promise you your lb7 heads and injectors are just fine... unless you plan on making over 1000hp don't worry about dropping a couple grand on lbz heads and injectors
I'm sure it is fine but that doesn't mean I don't want to explore options. I like the idea of LBZ heads on my truck and I'm still intrested in checking it out if anyone has the info on it.
MuscleTruck03
Wants a turbo!! or two...
Mar 10, 2010
369
north ogden, ut
check out the DTS heads, they're a vendor on here.
Back on topic, that sucks bad man.. next time it would be a good idea to maybe come on here and ask about the guy, see if they have a good reputation and what not. Odds are someone on here will know the guy and be able to give you a good or bad. Good luck man and welcome to the site!
