The truck leaves next week and I'm getting excited. Figured it was time for a build thread. This went from a stockish re-build to a full out performance build real quick. All work is being done by Caleb at Blackout Performance with me helping out as much as possible. Machine work is being done by KMP Performance and it's not their first Dmax.
My goal is to able to run the 12.0/11.90 class and not have to push the truck very hard. When its turned up the whole way with enough fuel it should be capable of getting close to 1k rwhp and run into the 10s.
This what we decided is going into the build:
Mahle MotorSports cast pistons w/ valve reliefs
Carrillo Rods
ARP head & main studs
CompCams "medium" camshaft
CompCams valve springs & retainers
Keyed cam & crank
Full Balance
ATI Damper
Clevite H bearings
New water pump
New motor mounts
New oil pump
BorgWarner B375 T4 .90/87/3.0
RDL Castflow headers and up pipes
Same 40% nozzles that I've had for now-getting them flow tested
2x Cp3 & 100% nozzles sometime next summer
That should do it! I'll keep this updated with pics. I cant wait to see what piston failed.
Carrillo Rods
Keyed cam & crank
Full Balance
ATI Damper
Clevite H bearings
New water pump
New motor mounts
New oil pump
