My FICM relocation
ZeroGravity58
1,401
51
Maryland
seems like a waste to run fuel through it. Ive seen fuel temps of 160+ degrees during the summer. Plus all the heat it collects from being on the valve cover on a 200+ degree motor. I really dont think it will see no where near that much heat on the fender well without fuel going through it. Im going to keep on eye on it and see.
6,081
What did you do for the sheilded wire? i have yet to mess with those.
ZeroGravity58
1,401
51
Maryland
if you go to where the wire enters the harness it is not shielded. Its just a single blue wire. Where i cut it and it was shielded all it was was the blue wire, a bare ground wire, and foil around both of them. I just made my own extention with a piece of regular wire and a bare ground then i shrink wrapped them all together. i think it will work just fine considering its not shielded the whole way. i guess i will find out when i get it running.
JDPlowboy
624
zero gravity thanks for the info on the shielded wire im relocating mine and i remembered seeing somewhere that one was shielded but forgot, and the tip on being not shielded down by connector saved me alot of hassle!
NRA4life
May 9, 2012
11
Dallas, TX / Jesup, GA
What did you do about the fuel lines doing this mod? I'm trying relocate mine also because of the banjo fittings are always leaking. I had thought about disconnecting the 1/2 inch line on the drivers side. It has a quick disconnect fitting there but I was wondering if they make a barb that will hook up there so I can go ahead and run it to my fuel filter. How did you do yours?
NRA4life
May 9, 2012
11
I'm trying to do something similar, I'm having a helluva time finding fittings for 1/2 inch fuel line to do this clean. I need a 1/2 inch hose barb that will connect to GM quick connect. Seems like no one makes it. They have it for 3/8 and smaller but no 1/2 inch.
If you know where to find this, hook a honkey up.
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
I relocated mine and had no problems putting the 1/2 line to the old banjo fittings and not leaks at all,I ean 1/2 to a fuel block i bought from Jegs which has 2 3/8ths out 1 line going to each cp3 and i installed a 0 to 30 psi water filled gauge1/8 in the top of the fuel block,made for a nice set up.
I also found out about the sheilded wire the hard way as it was sending my refrance signal to ground and i had a no start.
