My Allison is Getting Hotter and Hotter
Elgavilan
Desert Rat
Aug 28, 2016
50
Arizona
I found this Allison flow diagram that shows the main filter (spin on) getting its oil from the cooler and sending it to the pump. Seems pretty straightforward no?
Sent from the Arizona desert
Elgavilan
Desert Rat
Aug 28, 2016
50
Arizona
Tothemax
xgmtech
Oct 16, 2014
607
new york
Fluid filtration is provided by two filter systems. A suction filter, located in the sump, provides general protection to the entire hydraulic system by filtering large particulates. A spin-on filter provides full-time protection for the control solenoids and multipass protection for the entire system. The spin-on filter is externally located on the converter housing at the lower left front of the transmission.
Tothemax
xgmtech
Oct 16, 2014
607
new york
Hydraulic SystemA common hydraulic system serves the torque converter and the transmission. Transmission fluid for all hydraulic operations, lubrication, and cooling comes from the sump and is supplied by the charging pump.
5,911
you would be wrong, spin on is not the main filter.
15,681
You just don't give up, do you? The Main filter is the sump filter in the pan. The control main filter is the spin on filter next to the control main regulator valve in the picture.
The only thing straight forward is you can't read and oil diagram worth a shit.
Elgavilan
Desert Rat
Aug 28, 2016
50
Arizona
The spin on filter is also mounted on the same manifold as the cooler out and cooler in fittings
Sent from my XT1254 using Tapatalk
CarolinaHD
969
NC
Please stop and go back to Duramaxforum or wherever you came from. This forum isnt for children or morons.
Elgavilan
Desert Rat
Aug 28, 2016
50
Arizona
Jeez, can't even have a good discussion without being called names, very intelligent.
Elgavilan
Desert Rat
Aug 28, 2016
50
Arizona
If someone has a hydraulic flow diagram that shows it better, post it up, I'm all eyes and open minded.
