For quite some time I have suspected my truck has a serious problem with its turbo bark, large amounts black exhaust on the bumper and a very strange sound note coming from the air intake almost like a miss.
After pulling the trailer home from up north the wife and I stopped at Merchant Automotive in Zeeland to see if they had any thoughts. After looking around for awhile and consulting with others they thought it sounded like combustion pressure might be coming back up through the intake sided as if were a broke valve spring or cracked head for instance. Either way they recommended that I not tow with it till they can look at it and do a full evaluation. They also checked the turbo vanes and found them to be working correctly as well as the fuel pump pressure.
This is going to be very expensive to make this right and I am unsure at this point as to weather it may get traded in depending on how bad things are. You win some and you loose some and I think I just lost this one. :Charger:
