Motors in, working bugs out. Need direction
Been tinkering on my lly all day. Had a fuel leak pop up on injector 3 at around 55psi of boost on a tow tune. It's spraying outta the injector bore I believe. Shut it down before any harm could be done. Wonder what would be causing it to spray out? Coming directing around the retainer on it and sprays like a mofo.
Also on boost. I had rob Coddens build my dsp setup for my twins, injectors and dual fuelers. Cruising around in the subdivision it builds no boost. You have to roll into it a bit before it'll start spooling. Looked thru the tune and it should be cruising with closed vanes, but they seem to be wide open. Doesn't have any exhaust leaks around the block on manifolds or uppipes, so not sure why it's doing that. Snap on scanner and Efi it checks out fine. Any ideas or directions to go?
