Okay just swapped my lly out for another. Got everything all together and was priming the fuel system by compressing air into the fuel fill for the tank. Primed the fuel system up top from primer pump till it got hard started cranking almost fired and it suddenly stopped like hydro locked. Put bar on crank and could spin motor either direction, pulled glow plugs thinking it might be hydro locked on it and none where wet. Not sure where to go. also loosened starter and moved back away from ring gear still couldn’t get it to spin.
