motor build advise
06dmax
Aug 5, 2009
295
PIcking up a block and keyed crank for my lbz lookin to do a nice mild budget build to hold 650hp all day just throw some things at me on what you guys have done and what works well together thanks
Slammed2007Lbz
Super Spicy Tunaz
Feb 1, 2009
1,118
NE Ohio
Use the search button! There are about 5 threads ongoing right know with what people are using parts wise etc... Search is your best friend:thumb:
Schwinn68
little gearhead
Jan 9, 2008
632
Minooka IL
there have been quite a few good threads lately dealing with engine builds. take some time to read up on them and come back in here with some detailed questions. specific questions are much easier to answer than a generic "what makes a good build"
http://www.duramaxdiesels.com/forum/showthread.php?t=36312&highlight=budget+build+trent
http://www.duramaxdiesels.com/forum/showthread.php?t=28837&highlight=budget+build+trent
These are two very good threads with a ton of good information in them.
good luck on your build! Be sure to update this thread as you decide which parts you're going to use and why.
06dmax
Aug 5, 2009
295
i was debating doing hamiltion cam and springs. think that really needed i currently have a 4094 turbo but want to go a little bit bigger or maybe one day small twin setup but its mainly a dd with some hooks to the slep and a few trips down the strip you think cam and springs are needed? dont wanna spend the money on somthing thats not really gonna benifit me ya no
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Springs yes def worth there money , cam save your money and spend it on some Rods unless your planning on running higher RPM , or larger single turbo .
06dmax
Aug 5, 2009
295
Rods are already a definit I'm doing them just have been debating the cam but seems like I'm gonna pass on it
06dmax
Aug 5, 2009
295
Is gettin the main line honed absolutely critical or is it just recommended? What are the prices that you guys paid to get it done just want to make sure this machine shop is in line with his prices
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
The mains are alittle tight from the factory. I will be running stock main bolts BUT the machine shop line honed and bored the mains to open up the clearance for oiling and clearance purposes. You still could run stock clearances but why go this far and skimp on a 150 dollars or so. Thats how i look at it.
06dmax
Aug 5, 2009
295
That's the thing the machine shop wants to charge like 400 something to do it
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
That was just a number i threw out there. Im not even sure how much they charged me for. I do know that stock main clearance is .0028 and it is now .0033
06dmax
Aug 5, 2009
295
I'M located in Clinton new jersey ,
So far iv decided to go with
carrillo rods
Mahle pistons with valve release
Hamilton springs
Arp head and main studs
And keyed stock cam
Missing anything important?
