cubic millimeters of fuel?what does mm3 mean on the side of some of the tables ?
not exactly. And I don't mean to confuse anyone. It does not translate exactly to a specific volume. It translates to a volume reference. IOW 20 mm^3 is not necessarily double the 10 mm^3 as injected fuel. it is a minor misnomer.
The "reference" is commanded by the TPS (throttle based) table. But this does not actually define a fuel quantity, though that is the implication that the Kiwis built into the GUI.
You get, say, 100 (i'm going to leave out the units to make this easier) from the TPS table at WOT. You take that to the fuel pressure table, and then you take that fuel pressure to the pulse table. Now you have a pressure and a pulse definition, which together is what determines the actual amount fuel injected. Duration and pressure will define how much fuel is sprayed.
You can change up the fuel pulse table, say, double everything, so that you get a 3000 us pulse instead of a 1500 us pulse. That is clearly double the amount of fuel injected, but it is still reflected as 100 mm^3, (not 200). It will even still log as 100, though the truck is draining the fuel tank faster than ever.
That is why I wanted to clarify. I think the EFI guys should have written it a bit different to eliminate this confusion. The TPS table should not reflect units as mm^3, but rather a unitless fuel reference...IMHO
true. But i didn't want to complicate it further with compressibility and delay theory.
I don't know Ben, lets figure it out. I get 20 mpg when I am running 15 mm^3. Does that sound right to you, if so, we can do a conversion and see.
everything is compressible. True, we make assumptions in theory study to make things easy on ourselves. At 23,000 psi, liquids compress. I can't begin to tell you how much, but it is not trivial at those pressures.
WOW all that and i still dont know anymore them i did before sweet.
