Mismatched Dual CP3 Setup
3,727
296
Has anyone run dual CP3s with two different CP3s, like a LB7 and LBZ CP3? Let's assume they both use LBZ regulators, but are otherwise stock.
Just thinking about it for a minute, I can't think of a problem as long as the regulators are matched. Thoughts? Experience?
*If this has been asked before, sorry, the search didn't turn anything up. If you don't mind pointing me to those threads...?
cafryer
May 5, 2011
1,074
Utah
My old setup was a modded lb7 pump with a stock lbz pump and I also ran different regulators with no I'll effect
adeso
wait, what?
May 30, 2011
1,569
Minot, ND
I would think the stronger (so able to hold higher PSI pump) would do all the work until it wasn't able to keep up and was pulled down to what the other pump was running
edit, not sure how the regs would work, I would think that since they are scaled differently they wouldn't play nice
custom8726
2,784
Upstate N.Y
I ran a Stock LLY and a stock LBZ CP3 in my dual fuelers. I was told there was a voltage differance IIRC on the Regulaters so I used a LLY Regulater on both pumps...
