Mill and Lathe
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Christmas came early. The family got me a used mill and lathe.
I was a machinist 20+ years ago. I hope I remember what the handles do.
Lathe is a Select Machinery (import) 18x40" gapper with Mitutoyo DRO and 7.5hp motor. It has a 10" chuck and a 3" spindle hole. This is WAY overkill, about 3500lb.
Mill is a Supermax (import) 50x10" knee mill with 2 axis CNC control and power drawbar with 2hp motor. Oddly enough, it has a 30 taper spindle. 8-sp not variable speed. The control is a ProMax?
For imports they appear to be built well, the ways seem to be in good shape as well as the lead screws and spindles. The mill is 1-shot oiling but the lathe is not, but does an oiler for the ways.
Bought through Webb Machinery off the 15 freeway near Corona.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
I have to machine the electric motor's shaft before I go further. I got it cheap, but I need to get rid of the spline to mount a bearing.
It's going in the bed of the truck. The electric motor is 100lb.
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
Very anxious to see if the weight gain will be worth the increases. How many amps will it draw?
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
awesome Pat!! Congrats!
Get a nice VFD for that mill and you wont even need to mess with changing the belt for different speeds.
ben
lts1ow
Needs moar PAH!
May 14, 2012
1,598
NJ
It won't run off the truck batteries. 450amps at 108vdc. Serious power. Not a toy charger, something to take Duramax engines past 2000HP.
Where is like 50kva gonna come from?
If you stash a turbine in the bed, I can sell you a nice 90kva shipset :D
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Pat, Why do you have a reciprocating and a screw compressor in the shop?? Why even use the reciprocator?:confused:
The reciprocating unit is for backup/maintenance. If the rotary blows up, I'm out of business until it's repaired.
Also, the reciprocating will hit 175psi, my rotary is a 110psi model. I only use 60psi max in the shop and run the manifold at 90psi.
