Mild Y-Bridge Plates
Oct 16, 2008
948
12
Idaho
Thanks Russ. I should have been more specific, I need plates for LB7/LLY. I talked to David and they only have plates for LBZ/LMM. I'd have to swap runners and I don't think it's worth the $$ in my case to swap over. Might just have to find someone with a water jet or plasma table to cut some out for me.
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
The intake runners on the LB7 are better flowing than the LLY and the LLY are better than the LBZ.
Have you flowed them on a bench? Do you have numbers? I am finding it hard to believe that the larger inlet of the LBZ runner is being outflowed by the LB7 runner.
Bryce418
Still slow
Oct 5, 2009
611
I suspect Tony meant lbz instead of LLY.
The lbz bridge has a larger opening, but the intake runners aren't.
juddski88
Freedom Diesel
Jul 1, 2008
4,656
120
Chesterfield, Mass.
I have a set of LB7 and LLY intake runners right in front of me and they look pretty much the same, other than the LLY has the MAP sensor flange...?
Maybe he meant with y-bridge?
My opinion:
Lb7/LLY intake runners will produce higher velocity, but not more total flow, using a bridge of identical design. The only "restriction" I see in the LBZ runners is that the bridge flanges extend lower, thus creating more of a "lip" up to the intake ports. I like that the LB7/LLY flanges are wider than they are tall, but I opted for LBZ runners because total area was much more. There are two types of sheet metal intakes I would love to try someday: one designed similar to a LS -style intake manifold and then the other utilizes runners that are shaped similar to Rick's CastFlow exhaust manifolds and are fed by a y-pipe & single charge pipe from the front of the motor.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
My opinion:
X2
Sent from my PC36100 using Tapatalk
Tony Burkhard
Allseason Diesel Per.
The LB7 runners are not restricted by the turbo area like the VVT motors. You will find that the VVT motors have hotter #7 and #8 cylinders do to this restriction. Yes the LBZ/LMM runners have a larger hole but we can feed the LB7/LLY runners with the same size plumbing and not have the air hitting the wall that you will find in the LBZ/LMM runners that cause a nasty turbulance. We have spent much time on a flow bench to find what the good and the bad. We were working on our own intake runners but that has been put on the back burner for a bit.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
hmmm thats really interesting info Tony...I wish I had saved more LB7 runners when I had my hands on them. Ill take a closer look...every time ive looked at them, LB7/LLY runners all look the same to me but I guess not. Will the LB7 runners fit on a truck with a stock variable vane turbo in place?
Are the LB7 EGR and LB7 non-EGR intake manifold runners the same?
Tony Burkhard
I dont think you will get the LB7 runners to work with a VVT. I will know in a week or so about the Cali to Fed LB7 runners.
