LB7: Mild motor build
custom8726
2,784
Upstate N.Y
update :
adding a pic of pistons and ive added arp rocker studs to my list with Simons recommendationView attachment 13750
Looks good man:thumb: Guess thats why I never heard back from Todd today, he must have been busy with those pretty pistons:). Are they just De-lipped or cut aswell? Did Todd pin your oil pump? I never read anything about doing that, but while its apart maybe its a good idea:confused: While I am cluttering up your build thread with questions, care to elaborate on the need for ARP rocker studs?
maine04max
Dec 11, 2008
1,009
the stock bolts are not high quality and iirc someone had a failure , just cant remember who . as simon said you can put in 8.8 grade 10mm bolts ,,,,, i tried finding some local but didnt have any luck that route . he wasnt working on the pistons they were already delipped and just got back from the coating company . he is going to be pinning the oil pump and i plan to tig the gear on water pump also . now if I could just get a price on billet inj hold downs :rofl::rofl::rofl:
custom8726
2,784
Upstate N.Y
Ok that makes sense now, I'm a little slow today:banghead: Guess I will have to talk to him about pinning my pump while he has it. Why must you tig the gear on the water pump:confused: Can't you just tac it with a mig? I know there was a thread somewhere about it, But I have no idea the name. I will be back to the machine shop friday afternoon if your around :hello:
On Edit, I found the water pump/tig thread, originally posted by McRat..
maine04max
Dec 11, 2008
1,009
ill be down there saturday 8am ... hopefully picking up the motor ..... i have some slime green paint waiting to be sprayed on the block and valve covers :rofl:
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
I have Mig'ed them so far with good luck on a few water pumps i have done , after having one come off after 3 weeks in a customers truck with a brand new pump, i wont install one with out welding it , one tip i would throw in ......................... I drilled 4 holes in the Cast gear around the edge of the shaft .so the weld would poor into the holes so if it didn't bite the cast all the way it still couldn't slip. Welding cast with standard welding wire is known to crack because the weld cools so much faster than the cast , i also pre- heated the cast gear to about 250 before welding to help with the issue , recommended pre heat for welding cast is 700 deg , but i didn't want to risk hurting the seals in the pump from that much heat .
maine04max
Dec 11, 2008
1,009
well she is finally running:happy2: . we had a small oil leak on the oil feed for turbo , but got that fixed . only problem is now It sure sounds like i have an exhaust leak but cant seem to find it . its comming from up front somewhere . wierd part is when i turn left at an intersection it quiets down and when i start getting on it it it queits down nice out front and then i hear it out back where it belongs :rofl:
ill add some pics when i get a chance but im pretty sick with the flu at the moment
TrentNell
Jul 7, 2008
7,543
slc tuah
Congrats Craig ! Its a good feeling when they come to life after all the hard work that goes into a build ! Get feeling better soon :hug:
custom8726
2,784
Upstate N.Y
Good to hear you got her going man:thumb: Hopefully the weather man is wrong this weekend and the diesel drags / Dyno will still be happening... Are you going to make it down if your feeling better and its not raining??
maine04max
Dec 11, 2008
1,009
doesnt look like ill make it to the valley .
Henry I need that address to send the install tools back to you
