mike's c3 oiler
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
I have been running it for 6 mounths or so , my c'3 had black rings from not getting enough lube last time i tore the trans down they were only 5 mkounths old and alto clutches and had no wear acording to the micromiter so they werent slipping , after seeing this i had mike set me up with his oiler great product , cant vouch for running cooler i already had mike's trans cooler so temps were already low , if you run your truck hard or hot lap at the track it is a great product to buy . your c3 clutches def take the most abuse so any cooling and lube you can give them the better off your going to be . its flows alot of oil to those clutches :cool:
come on guys do you expect anything sub par from Mike ?
15,681
x2 im interested in this also. does it in fact lower trans temps also?
I doubt it will lower your trans temps noticably. The snake oil was designed to cool the C3 clutches for racers or hard working Alli's. It will give you full time lube on the C3's.
Cornell
LBZ for life
Sep 11, 2006
1,601
Minnesota
My buddy is running Mike's C3 oiler with his Stage V. I could ask him but I doubt he noted a difference, because he just wouldn't notice something like that. :rofl:
stroke250
I May Be Lost...
Jul 1, 2008
490
Idaho
what is a good time to call tomorrow mike?
kodiak
Sep 25, 2007
178
Mine has been on since Mike first designed them...something like 2 years ago??? I tow heavy and have done so all over the US and Mexico. 117,000 miles and my built trans and clutches run as well as the day Mike installed them.
IdahoRob
Jun 5, 2007
1,151
Seems to be a factor on my truck. Basic tranny build, holding well over a year and 100's of passes in the 11's and 12's.
I really need to tear it down and look things over, but it's shifting so damn well....
jason86
Marv
Dec 30, 2008
78
Sacramento, CA
I've had it for about a year and have beat the hell out of my alli and no problems so far. and the cooler works amazingly well.
mike makes some seriously good stuff.
