Mike L- Per our conversation
15,681
All your brace will do if you have a issue is hold some of the broken pieces together.
Correct.
Braces will not do squat for support. What they will do is hold the broken pieces of a shattered transfer case in suspension and keep them from falling on the track where the rear tires can run over them at high speed.
The braces will NOT save anything from breaking.
Big Block 88
Multiple choice muscle
Nov 3, 2008
4,665
Kansas when I am home
Correct.
I never knew that, I had a brace on my last 07 thinking it would save the tail housing...:eek:
DBUSHLB7
Team DMAX
Mar 9, 2012
2,789
Albuquerque, NM
Question....with the billet extension housing not breaking...where does the driveline problem now transfer to? The bellhousing as my brothers LBZ experienced?
15,681
Most people that have had broken tail housings chose to ignore the vibration.
When you feel something wrong, and you will, fix it. Don't ignore it and put it off.
An anvil can be a weak link if you continue to let it vibrate.
Evan@InglewoodTrans
yerp
3,118
65
Western MA
If you get to the point you let a driveline issue hurt the bell housing then you earned your repair bill.
On edit: Mike beat to it but worded it much better.
Mile_high
The Mad Hatter
Oct 31, 2009
702
Denver, Colorado
I have several duramax work trucks that my guys drive in addition to mine. After reading this thread today I looked at some service records and discovered that we have busted 5 tailhousings, one rear engine plate, and one bellhousing in the last two years just in our small collection.
I'm positive that none of my guys would stop driving if they felt a vibration. :eek: Most of the time my trucks have a loaded trailer hooked to them and they are off the road in a field or hopping a curb.
Mile_high
The Mad Hatter
Oct 31, 2009
702
Denver, Colorado
If you have to ask, it's more than you can afford muahaha, see what I did there lol
Most of the time, you are right!
It's like those billet rear engine plates DHD sells. If they were more like $800, I would have one on every truck that has broken a stock one. Since they are $2K each, I own zero. :(
DBUSHLB7
Team DMAX
Mar 9, 2012
2,789
Albuquerque, NM
You misunderstood me. My brother did not cause the damage to the bellhousing on his LBZ. The previous owner did as can be seen in my thread called Trans carnage. He bought the truck with that problem. My question was not related to fixing a vibration issue, it was where would the problem show up if an adapter wouldn't break? My guess was the bellhousing and I was seeing if others agreed or had a different idea.
You misunderstood my question as well and the genuine nature of the question.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Correct.
So a transfer case brace is snake oil that everyone is selling to put money in there pocket, knowing good and well it dont do shit?
I put a brace on my manual trans as it will help.
15,681
If I was drag racing I would have one. Anyone that drag races or sled pulls should have one.
5,933
Sometime keeping shit from putting you into a wall at high speed is a good idea ;)
