Max Vane
Killerbee
Got Honey?
if you want to send me your tune, I will compare it against your log for correctness.
Vane position begins to decrease well before your set point (desired) boost is realized. This is integral control logic at work.
Use your brakes to induce the load you want at a constant speed, and hold it here for a few seconds. Then play back the log overlayed onto your boost C table. Assuming you are 13.9 baro or higher.
[email protected]
cmitchell17
Sep 8, 2008
251
Ok thanks for the help I will send you my tune. I know what equivilance ratio is but the only thing is with a modified pulsewith table I would think it would not work. It would be nice if we had a bigger pw table that had more mm3 on it.
Killerbee
Got Honey?
On quick view of your tune and log, it gives every indication that your vanes are getting hung up over 95% (when max table says 80ish). It could be that the 90+ positions tend to jam. But you are definately overboosting with the assistance of the vanes. Frame 1395 is a prime example.
I am betting somebody else has already seen this happen.
[email protected]
cmitchell17
Sep 8, 2008
251
I pretty sure it is the same tune. I will reflash it and take another log. I don't see how it could command 100% when I still have the stock Max vane tables in my tunes?
[email protected]
cmitchell17
Sep 8, 2008
251
I looked back at my logs and I saw the 100% vane position while desired was at 88% but it was while it was coasting at 42mph with no throttle. It was never over 88% at WOT, only when I was off the throttle?
[email protected]
cmitchell17
Sep 8, 2008
251
Ok I think your looking at the wrong log this is the one you need.
This is the log I took after putting the mouthpiece on.
  • Log 11 (After MP) (5.83).zip
LarryJewell
Back with his honey :)
Jan 21, 2007
10,152
58
San Angelo
FWIW, not too long ago my vane position "stuck", I dont remember if it was more on the open or closed side, really doesn't matter. Anyway, turned out I had a bad ecm. Now, the dealer wanted to sell me a new ecm for $1500 :rolleyes: but there are several good vendors here that sell them for significantly cheaper, say by 2/3rd's.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
hook up a drive pressure gauge, it will open your eyes ;)
It did for me:)
for the purpose of spoolup, not concerned about DP.
Then dont call it drive pressure and just use it as a tool:hello: Im suprised you wouldnt be interested in what the turbo tuning is done to your drive
Me personally Killerbee, I would try pulling even more under 60% when fueling, in some situations less boost is better ~~ I know that can be an argumentive point. (flame suit is on)
I agree with you and im willing to bet you would have less drive pressure also and lower EGTS
Pull the vanes down lower than you want and then build up from there. I have found that method to produce some tire raping burnouts. lol But I am talking about pulling the vanes AFTER the turbo has possibly lit--once it lights I think its far better off being opened up, I know I was surprised at the boost levels the turbo would maintain after it lit and the vanes dropped way off.
Just curious, where are you having problems lighting the turbo? as in mm3/pw/rpm range? then timing.....I know theres alot of variables.
I agree:)
disregard target position, it has no real effect on what you are after, it is the single most misunderstood table. It should have just been left in the background IMO.
I dont understand it....but I also know it doesnt do squat!:D
[email protected]
cmitchell17
Sep 8, 2008
251
So does anyone think 100% vane or close to it is beneficial to spoolup at low boost?
Stock seems to think it should never go above about 85% under 2400rpms?
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
I've never seen a need to go anywhere near 100%. A max of under 90% will spool fast enough to break tires loose at 35+mph on dry pavement. There is a lot more to tuning for fast spool up than VVT tables.:cool2:
catdiezel
Body Type: MULE
Mar 10, 2009
15
Broken Arrow, OK
It did for me:)
I think i figured out how to MAKE the target position table work....... Short on time--thought i would stop in---ill look at the table later that I THINK will enable or disable those tables.......the target table works FINE at idle--keep that in mind.
othrgrl
Mar 10, 2008
2,151
Wilmington NC
So I guess I need to figure out how to make it not command 60%vane position when it is at full spool already overboosting.
At high fueling (80mm+) you shouldn't need anything over 60% from 2400 RPM and up - Vane Position should be dropping off as RPM goes up.
This basically acts as a waste gate (and is the reason VVTs don't have wastegates) and lets air through the exhaust housing without it having as much affect on the turbing wheel.
In reality you are changing the AR of the exhaust housing - the air isn't bypassing like it does with a waste gate.
KB you like to experient with air flow stuff and spreadsheets how about you take a stock turbo and figure out the AR of the exhaust side based on Vane Position and come up with a table for us.
Example:
100% - .75 AR
90% - .8 AR
80% - .89 AR
And so on.........
