Max lift pump pressure?
Sledheadxp800r
That was only my tow tune
Dec 13, 2010
1,151
39
I'm relocating my ficm and running it dry. Now that I don't have to worry about my ficm how much lift pump pressure can I run before it starts causing issues? This will be on my puller that gets trailered everywhere and sees very short run times.
juddski88
Freedom Diesel
Jul 1, 2008
4,655
120
Chesterfield, Mass.
I have mine at 6psi. No need for any pressure at idle. When you fool with the regualator tables to compensate, you will most likely take away responsiveness down low
Noreaster
2,910
42
Cape Cod,MA
turn it up till it effects the idle, I used to run 11psi with stock cp3 but have to run 8psi with the lbz fpr to keep actual RP close to desired
Sledheadxp800r
Dec 13, 2010
1,151
39
I think I'm going to go with 2 of the new fuelab velocity 200gph setups. They're like an airdog or fass but they use a flow through pump. They are regulated at 8psi and all the pumps come with a certification sheet with flow specs.
05chevy
1,086
I just put a raptor on mine. Psi was already set a 20. Seems to run smoother at 20psi then 12psi that it was at with the ppe
Sledheadxp800r
Dec 13, 2010
1,151
39
Here's the fuelab 200gph system if anyone is interested. Part # 30304. The install kit does not come with this part #
