don't alot of people use a mustang II rack in project vehicles ?? iirc they have one that's manual
Not really but need to find out , 4-wheel scales are expensive , even to rent them
Trent, moving that much weight that far back i feel will give you negitive effects. weight transfer is a funny thing, and on a 4x4 is even more important, because you need traction on all 4 wheels not the back two.
we played with this a few years ago when i was running my silver truck and i kept taking weight off the front and our traction got worse and worse,The front tires would spin, but i had no locker or anything. eventually we found that the weight up front was a good thing, weight % was 70/30, but remember during inertia(launch), the weight will transfer as much as 40%
It seems that for the few 10ths your going to pick up it might be cheaper to just add a little more fuel and air :thumb:
I may hit you up on that Chris :hug:I've got scales if you want to borrow...
Hitting it softer and netting a better 60ft tells me you need a progressive boost controller..:cool2:
We'll see and ya i agree the truth is in the "middle" , my last 2 events I was fighting pretty bad exhaust leaks , turbo's were kinda "On" or "Off" and even on wouldnt clean up well until the 1/8 mile where as when i first put them on I could get 2-5 psi out of the big one while staging, so I cant say for sure the chassis is at fault , the last event I would just get on them as hard as i could just to ensure they would light to make sure I won the round , new turbo setup should be bigger air and light easier if my plan goes right .
