damn that was nasty....
Is this what the BD BOV's sound like?
http://www.youtube.com/watch?v=T7zQHag-FSQ
yep
I installed a 200 dollar Tial BOV on my charge tube and oppose it using drive pressure. I can get you pics, source for supply, and steps to get it done. Just ask me if you need help with it. Cheapest and most functional I found, and it works great! I did it cause my turbo barked bad after loading a hot tune and pushing 35+ pounds boost.
On a stock charger? that doesn't make any sense sounds like it was your tuning.
Yes, a stock VVT. Barking was because of the hot tuning, otherwise I would not be anywhere above 26PSI, as almost everyone knows what the factory turbo does with a stock tune.
hmm... mine never barked with a 500 tune only when I did my first and last burnout and let of really quick but im sure the BOV will help the longevity
What exactly does the barking affect? More shaft play? Worn out edges of compressor wheel?
Mine barks when it locks the torque converter in 5th gear haha.
I made a totally new tune the last few days. Loaded it today and it runs better than the old tune. Way less timing, quite a bit less fuel. Think I got a max of 2300 pulse width and timing at 2000 rpm and 45mm3 is about 5 degrees, max timing is 23 degrees.
I'll try and work on the tuning over the next few days. The turbo spools nicely and makes good boost, wraps my 30psi gauge fast!!! I'll buy a 60psi unit soon.
I will most likely buy the BD unit... I'll look into the DIY setup, but after changing head gaskets with the motor in the truck, putting ont he new turbo, changing a bunch of suspension/steering and swapping 8 shocks out, I've about had enough of rigging stuff up. It would be nice to buy a unit that isntalls straight forward and easy.
Anyone got a link to the duramax BD unit? I looked on the site, I didn't see one for the dmax?
