LB7: Massive HP fuel leak
DewDewMax
Drive fast, take chances
Jul 9, 2014
105
Sudbury Ontario
Long story short when I finish up building my motor went out to torture it and discovered a massive hp fuel leak when commanding high rail and under load. Dumped some die in the fuel, unplugged my reg and found my hp leak. Was just a couple bad leaking injector line, replaced it with ones I had laying around. Now I'm back to making oil again. It has to be a hp leak as My crankcase is full again in about 30 minutes worth of abusive driving. Ordered a set of brand new high pressure lines and hoping to solve my issue, wondering if anyone has any input. Thanks!
JLB7
Oct 27, 2015
13
California
Worth pulling the oil fill neck and checking the cp3 front seal for a leak while running. Not very common but it is possible.
