How did you hook it up? the oil pressure sensor screws in and the map is just oring sealed? Did you have to splice wires too or did the plug work fine?
Used a volt meter to figure out the wires
used a old harness with the weatherpack for the oil sensor and then cut the wires off the boost sensor and solder the to the oil sensor
I actually left the stock sensor in place because it was a oring seal and just stuck the oil sensor into the y brige
You can put it anywhere you like or even use it for drive press, lift pump whatever you want to log really?
I used a hand a air compressor and manual gauge and efi to rescale
you could most likely get a sensor and harness from autometer for around 80 bucks
