Allison 5sp: manual shifting or leave alone
strongsperformance
2002 sierra cc dually
Jan 14, 2011
78
lake orion michigan
I have been a drag/street car guy until now. I like my 10 sec cars but just too much of a hassle to keep them streetable and enjoyable so I built up the dmax
My question is. Is it common to manually pull truck to a lower gear when wanting to stomp the pedal like I would in a street car or just leave alone in drive and let trans do the rest.
thank you
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
10
Wyoming
thank you
probably easiest just to leave it in drive...the allison is completely electronically controlled (and shifted), so its not like the trans is going to react instantly to you moving the shifter and its not like its going to shift to exactly what gear you select immediately.
Mike L.
15,681
232
Fullerton CA
The Allison will upshift and down shift when the computer tells it, not when you decide to move the shifter. The best yo can do is hold it in gear with the shifter.
strongsperformance
Jan 14, 2011
78
lake orion michigan
I thought so but I thought i'll ask anyway.
Thank you
turbostang7
Apr 11, 2011
239
Rexburg Id.
What is the intake air heater delete mod that you have listed in your signature and did you pick up any power?
You turn off the iah with efilive or something similar, and then remove the heater. I didn't notice any jump in power really but it has to help Haha if you search it there is some photos on here about it
Sent from my DROIDX
strongsperformance
Jan 14, 2011
78
lake orion michigan
Well I noticed a little better spool up when I first did it but I had no mods at all on truck. So it worked then. The heater is located below your map sensor on intake housing. I bought a cummings diesel drain plug and plugged the hole where the heater was.
I did not use efilive to delete it. I left it plugged in then threaded lightly into a 7/8 china deepwell sockeck and then hose clamped it to my steel upper rad hose that way it is still grounded and works so the computer wont throw a service engine light and I can easily install it in winter if need be.
