Manley Dmax Rods
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
There has been at least one major rod mfr who didn't get the Dmax rods right. Not DuramaxTuner, a real rod maker. They bent the beam significantly when big power was applied.
Competition is good. Hope these are tough rods.
wasnt it cunningham?
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
The ones pictured in the other website had too small of a small end, too small of beam, and too small of fillet radii. That probably would not work in a diesel, look like high RPM NA pieces.
2,022
They should have atleast put a real pic of the rods lol. They were around that price though. Saving $400ish dollars on a mild build is a big chunk if your only wanting a mild build (cut stock pistons, gaskets, studs, bearings, key cam/crank). Less then $4k in the build after balance.
Russ, what do these rods weigh compared to stock? More or less than Crowers and Carrillos? Also, has Manley published what material these are made out of?
05smoker
I'm officially done!
Mar 30, 2007
2,379
Lebanon, OH
Picture may not be right but the part number is.
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
Just sent everything to balance, I'll get some weights next week. Here is what Guy posted in his section of the fourm
Manley BE 728g SE 411g
Crower BE 769g SE 377g
R&R BE 769g SE 387g
Carrillo BE 672g SE 416g
__________________
