malibu795 can't pull a sled with a 2wd...
650
Didnt say anything last night , but did notice that Lawrence pulled the hell out the sled compared to Adam ....... :rofl:
yes he did. and a lighter sled none the less.. i wanted to pul with the 2.6 class guys at the same weight with a 30" hitch and tires..
that was my goal and i placed top 5 iirc out of 11 trucks that pull.
and watch the front tires in the first 100' or so... got the tires off the ground :eek:
http://mcratracing.com/k/adamsp.wmv
smaller tires and blocks in the front and up they come :D
Gasuout
Johnny
Mar 20, 2008
2,188
Santa Ana , Ca.
Glad you got to have some fun Adam , I know how it feels to be without your truck for a long time . That was very cool of Lawrence to let you take his truck for a spin .
Johnny
WanaDmaxsub
Junior Member W/gray hair
Feb 17, 2007
644
sad thing is lawreance and i didnt pull the sled at same setup.
iirc i thiink i pulled 4th in distance after they got the sled adjusted
:blah::popcorn:
:poke::jk:
650
lawrence didnt want too.. had to talk him into pulling @ 30" :rofl:
i want to drop the tb and put a 25" tall tire on the front thats almost a 8" drop in the front
and block in the front
2wd_Sled_Puller
Heavy Equiment mechanic
Feb 19, 2008
1,356
Florida
x2 do that and drop t bars all the way down below stock height. It will plant the back tires so much sooner and make one killer ass hook. it looks like your tracks are like ares so run about 25 psi in the boggers. If it startes to hop a little pump up the pressure. Run 60 psi in the front tires. Adam if needed i will put all my sled pulling gear on my truck and weight the front end of the truck how it is. That away u can get your tires to be just about mine. U only want the front tires a couple inchs off the ground. The truck looked awesome it can deffantly be a first place truck with a little more set up.
2wd_Sled_Puller
Feb 19, 2008
1,356
Florida
Just keep a eye on the tranny leaking from the front seal. Ive been threw 3 so far this one is final when my tax return comes in i will have a converter for my truck
650
O ok then u will have no problem i thought the tranny was still stock
lawrences sig
'04 C2500HD D/A LS EC SB, Chrome Nerf bars, Grandson's "throne", Prodigy, Weatherflector, Breezer, A.R.E. Z w/accordion boot, Bedrug, H2's, Bilsteins, Predator, VR Straps, Bowtie Flag, Mag-Hytec's, SPA Boost/EGT, Katless 4", BigMouth Grille, SD Manifold, SCIII .50 Hot Rod Allison/TTS triple, Airlift Superduty bags, Banks Bighead, Fugly '06 Mirrors, Van Aaken 230, Garvin Wilderness Rack, EFILive, Cognito Idler/pitman braces
