So the new radiator will require me to extend the trans cooler lines as the heat exchanger is on the driver side now. i dont want to use all rubber lines like the deviant setup or others like it. i would rather cut the crimps off the factory steel lines and use compression fittings on the lines with hose rated for the temp and pressure the trans sees.
question is, the compression fittings im finding are only good to 280psi and hose is only good to 300psi. right now, mike has my pressures above 300psi and i know the coolers are prone to seeing spikes to 300 or more. has anyone found a compression fitting rated above 300psi and a line rated above it? If i have to, ill get a weld on an fitting and have it TIG'ed to the stock steel line, compression fitting is just easier if there is one that will work.
Yes i know i could go with the DHD or the like and have them make me extended ones but id rather make the lines here so i can run them how i like.
