Making 2500hp hold
IdahoRob
Jun 5, 2007
1,151
Crank and Block are the limiting factor IMO. We now have the fuel and air possible, but even with the high dollar/best products currently available, a true 2500hp won't be reached, not without total destruction. Hopefully someone proves this wrong.
Custom big cube blocks and cranks are not a Duramax just because they have Duramax injectors and ECM.
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
My thoughts exactly.
TDFDiesel
I'm That Guy
Jan 6, 2011
386
Mesa, AZ
I agree 100%.
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Dyno
What I mean is a big spike number on a dyno means nothing. I'm pretty sure there is some pulling motors making big power there just not glory hounds. I guess I should have been a little more clear. I bet my motor (as I run it) in the dragster is not making 1000 hp. That is at the crank so 850 or so at the tires. The chassis is using it and the numbers don't lie. Sorry
Cknight199
Aug 23, 2012
1,827
Salt Lake City, Utah
I would agree with that. But I think that a different crank in a duramax block should still be classified as a duramax regardless of the crank. Aren't there several cummins that wouldn't be classified as a "cummins" because of the custom block they run?
SmokeShow
6,818
Lawrenceburg, KY
traditionally, the "brand test" has been that if the engine can still accept and swing a stock crank, it flies as being a *fill in the blank*. I'm guessing that limits you to bore separation and ultimately limits your cubes unless they add height to the bores to gain cubes. Either way, I'm ok with that designation.
Once it can no longer use a stock crank (aka has standard bore spacing), then it's just XYZ's engine.
That's just how I see it.
Cknight199
Aug 23, 2012
1,827
I agree with this.
Muff
Just Learning
Oct 7, 2013
1,063
Butler, Pa
Id love to know the horsepower that Tim Jacksons pulling truck was putting down when it was fresh its last season out. That thing was nasty. I read somewhere that "he" was having rods and pistons made specially made for that truck because they kept breaking or bending aftermarket parts.
Bonestock
1,358
Worland Wy
That Truck was Baaaaad! I miss seeing that thing jerk the sled out of the park!:eek:
