Main Cap Walk
9,905
151
If it has spun a bearing or out of alignment on the mains you will have to cut the block side. If you cut the block side it will change the CL. I don't care how good you are "IF" you cut the block it will change.
Unless you have thicker bearings to bring the crank back out away from the cam then absolutely it will change. It has to.
