Mad max LIVES!
wrcknkrw
447
roy ut
Can't wait to see it in action. Sounds pretty cool with open headers, doesn't really sound like a diesel.
IdahoRob
Jun 5, 2007
1,151
Damn work keeps getting in the way. Trying to have it running for Woodburn this weekend. I don't even know if it'll go straight, so it'll be low power, slow passes if we make it. Only running one wicked cp3 as the hard lines are not done.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
What kind of water pump is that? And the can below the turbo for oils is that because it is so low that you worry about it not draining to the pan fast enough?
Is it a dry sump oil?
Looks so nice !!!! Love ti see it in person.
Good luck guys!!!
IdahoRob
Jun 5, 2007
1,151
Simon, we are running two electric water pumps and feeding each side of the engine with each. There is a remote oil cooler/ oil bypass/pressure regulator on this that is cooled from the radiator same as maxed out.
The turbos have there own oil supply, tanks, and pumps separate from the engine. We did this for two reasons, like you stated the drains are a bit low and second i like having separate oil for the turbos.
