Friend of mine has the beltech 3" drop shackles with lowered t-bars. I really like the look of it.
You sure they are Belltech? All I see is 2" drop spindles and 1-2" drop keys.
I'm pretty sure they are beltech. I will find out for sure.
I thinking about cranking my T-bars ALL the way down with my 35s just to see if I can do it.....if so, that would be freaking great.
Belltech does indeed have 3" drop shackles. Part number is 6403 off hand I believe. I have them on my truck.
If you want drop keys you have to go with Mcgaughy's. IIRC the Belltech ones are only for 1500s. You can use the Belltech shackles though. IMO if you are running a 17" or larger rim the best option is drop spindles.
I have 18"s......You happen to know what the benefits of running spindles over keys would be? Pretty large price difference there.
trust me, kyle is the guy to talk to about lowering these things. take his word for gospel:hug:
The spindles will get you lower without changing the geometry of the suspension. It will not bind ball joints or cv's. HOWEVER you will lose a bit of turning radius. Also spindles will allow you to keep the stock keys therefor the ride quality will not suffer.
