lowered truck pics
THEREDDEVIL
A Bad seed
Jul 28, 2010
512
Godfrey, il
How much triming will I need to do to run a 10 inch wheel with 4.5 bs on 35s? Front end low as it will go on stock keys lol. Front bumper removal required with this setup?
Sent from my PC36100 using Tapatalk 2
Lots of trimming, and the big issue is contact with the washer fluid resy. Mine has a giant hole in from running 35's with tbars all the way down. And I only had 2 hooks and very minimal street miles too.
sddmax
<---- Gone Forever...
Feb 9, 2010
224
35
Garretson, South Dakota
Lol might need a torch and a sledgehammer to form the rear of the fender and front of cab and floor pan around the tires along with the bumper removal :D
Sent From My HTC DNA
sddmax
Feb 9, 2010
224
35
How much trimming you talking about? I haven't trimmed anything on mine as of yet.
On the lower valance I measeured 2-2.5" iirc towards the front, then taped from that Mark at an angle up to the lower corner of the upper bumper cover and trimmed that off. On the back side of the fender I cut slits in the body crease, folded it over, then cut a slit and removed maybe half inch of material to move the lower part of the fender to match the new location of the body crease.
Used a few self tapping screws to hold back the fender liner, and there ya have it. I think what I trimmed on the fender and the body crease is similar to the norcal truck fender mod.
Carolina326
Feb 24, 2013
3
Thanks, going to take a look at the fenders this evening and see what I can do with it. Hope to get a lil better ride out of this thing.
jdaniel
Jan 16, 2011
21
hey i have a 07 classic four door and i wanna lower it down and need some help right now i have 20x10 bmfs and im curious what size tires and what size lowering kit would be best.. thanks
Kspen90
<<<got turbos?
Jul 14, 2011
1,433
Burleson, Tx
I'm running 305/50-20 with the keys all the way down in the front and a 2in shackle in the rear, but the rear really need to go sown another 1-2in to look right imo.
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
ImageUploadedByTapatalk1362776508.067816.jpg djm drop hangers set on the bottom hole(2") with 3" shackles set on 3" drop. So right around 5" of drop in rear, torsion keys with bolts out in front. Mcgaughy keys will be going in after I put my wheels on. Still have overloads aswell. Running kyb shocks in rear and rancho adjustable 9000's on the front. Rides really nice!
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
To lower a truck you first need to look at the specs of the rims.. so, what is your backspace and offset? That alone will make or break a lowering kit on a truck.
View attachment 27254 djm drop hangers set on the bottom hole(2") with 3" shackles set on 3" drop. So right around 5" of drop in rear, torsion keys with bolts out in front. Mcgaughy keys will be going in after I put my wheels on. Still have overloads aswell. Running kyb shocks in rear and rancho adjustable 9000's on the front. Rides really nice!
Looks good! Needs more low... remove the overload and 2 leafs :happy2: :D
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
Thanks Brian! I have a set of mcgaughy 2" drop keys just to give it a tad bit of rake in front or I may put them in and move the spring eye to the top notch of the hanger. And have the truck sit level. The 20x10 -19 offset wheels is what the deciding factor is on the front end lol. I'll have to cut some on the inner fenders but I could care less. I may not run any liners for the summer if it won't hurt anything. There wide sons of bitches
jdaniel
Jan 16, 2011
21
well my wheels are 20x10 bmfs there 4.75 back spacing and -19 offset probaly the worst wheels for lowering a truck but hopefully we theres some way i can make it work.
1slomax
Dec 6, 2011
260
Harrisonburg VA
A 3/5 drop with -19s on 285s will still prolly run Bri Bri I had to cut my bumper with he stock front end with the bolts almost down and it still rubs
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
ImageUploadedByTapatalk1362858300.417223.jpgImageUploadedByTapatalk1362858316.992258.jpgImageUploadedByTapatalk1362858335.821852.jpg
Here's with the wheels 20x10 -19 offset with 305/50 nitto 420s. 4-4.5" drop in rear right now with the overloads in and the hangers set on the lower hole. I plan on running the hangers on the higher hole and the drop keys about halfway down. Should be real close to 3" drop in front and will be a 5" drop in rear. Rubbing isn't horrible as of now. She Definatly needs to go lower I think!
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
So how long did it take you to do the work?
I had Justin P do the hangers at his work. Took him about 3 hours which seemed pretty quick. I put the kyb's and ranchos in the night prior to him doing the hangers. Truck rides pretty nice aswell.
