lowered truck pics
Hernpj01
On a Time Out
Sep 23, 2014
403
Indiana
Crappy pic of mine front is lowered to flat out cv angles
lutzjk913
1,697
188
groveport, ohio
I can't get caster/camber back in spec with just keys alone. I'll eventually go with the djm arms. For the rear I'm not sure I want to stay as low as I am now its a true 3/5. I guess it will depend on what the 20's will look like when I get them
You have any pics of yours with the 3/5?
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
This is with a 265/70/17
picture.php
kivetts04dmax
May 20, 2010
742
Boonville, MO/Pendleton, CA
With the help of my good friend Josh Chambers (chambersj on here), I lowered the rear of mine about 2 more inches last night. It now measures about 4.75" between the top of the tire and the top of the wheel well opening both front and rear. While we were doing it, we also raised the shackle hangers a couple of inches so they don't hang down below the bottom of the roll pan. I'm not sure if anyone else that has a roll pan on their truck has noticed it, but it has always bothered me to see the bottom of those ugly shackle hangers sticking down below everything. It looks so much better now. It also rides much better. I highly recommend putting the front spring hanger brackets in. I'm posting a pic, but please try not to pay too much attention to how filthy my truck is. I don't have much time during the day to wash it, and my weekends have been pretty busy lately.
attachment.php
Did you raise both front and rear hangers? If I decide to go lower I might just raise my hangers like you did and LCAs in the front. Is your front stock just lowered torsion bars?
carhauler
Oct 20, 2009
lowered dually
Lowered 2/5 spindles and shackles and hangers , custom air bags pull at 30,000 all the time
moparkxracer
2,309
33
Out and about
I had to get the lower arms to fix my alignment.
picture.php
20miller12
Aug 27, 2014
24
Not sure which company made em but ya gotta have 17+ wheels and I'm just gonna stick with stock suspension with the 3.5" body drop
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Gonna sell my drop spindles if anyone wants them 125 shipped
what spindles are they? what are you getting?
If they are McGaughy's their name is cast into the face of the spindle along with the 17" wheel requirement. Some aftermarket 17" wheels do not work and you have grind the lower ball joint stud partially off and install their modified nut with the Hummer wheels, if in doubt call them like I did......
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Sent a few PM's back and forth with chevy1925 about lowering and lifting 2 inches by adjusting the torsion keys and this came up...
FYI
one thing alot of guys overlook when lowering or lifting their truck is the loosening of the LCA mount bolts and UCA mount bolts until set to ride height, then retighten. guys dont realize the bushing put under tension when you move the suspension height to somewhere else besides stock. leaving them loose allows them to be in a "neutral" position when set to the desired ride height and the bushings will last a much longer life span.
