Weak fuel rail saftey valve just a suggestion to do a bottle test
http://www.duramaxdiesels.com/forum/showthread.php?t=1995&highlight=bottle+test
Hope this helps.
FWIW the only low rail issues I have had was due to the FPRV. If at first it doesn't leak then drive around a bit and try to make it pop.
Brandonkinney have you checked your engine oil to make sure there isn't an excess of fuel in it-from a hung injector or something? Also see if you can get someone with a Tech II or EFI Live to check your balance rates if you don't have it yourself. This might help eliminate injectors as being the issue.
