Alright I have a buddy thats having some issues. His truck is a 2006 with the 6 speed allison. I thought that meant it was an lbz but according to his vin its an lly. I ran a check with my v2 and I could not connect to it as an lly, but when I changed the "connect to" to lbz it connected and let me do the log. Point is its a late lly or early lbz.
Mods are as follows: Bully dog set on stage 2 (he never told me what kind of bully dog it was) A power play MP-8 (a box that sits under the hood and plugs in line with the fuel rail pressure sensor and the MAP) has stock exhaust, intake, and no lift pump. All mods have been removed since problems started.
Problems are as follows:
Truck had bad diesel knock and just shut off one day. Was able to restart and get it home. The owner found one fuel injector was bad (don't know how he did). he changed it and took the truck for a drive, then blew all the freeze plugs out of the cp3. Changed the cp3 twice with brand new ones and the truck ran good, but now anytime it gets driven when it hits 2k rpms it throws a low rail pressure code and goes to limp mode. The desired and actual rail pressure were the same at idle. when revved up in D with the brakes on the desired goes up to almost 21K psi but the actual never breaks 10k. It did not throw a code while i was doing this. I can't figure out how to post the log. Any ideas?? Could the rail pressure sensor be bad causing a false reading tricking the computer into thinking it has low rail pressure when it really doesnt?
